Hannibal
Sep 07, 2015Explorer
Cummins12V98 wrote:johndeerefarmer wrote:up2nogood wrote:Hannibal wrote:Cummins12V98 wrote:johndeerefarmer wrote:
I have only had mine a few months. I always do the pull test but for added insurance have one of these. Lots cheaper than a tailgate and new sides for your truck bed.
http://www.5thwheellatchkit.com/
Look at the bottom pics on the site listed. It is a B&W hitch. If you have their product you would have to get your face right up there to install the bar with this product. So if all you did instead is LOOK at the jaws to see they are wrapped around the kingpin and the hitch and kingpin plates are touching and the hitch handle is closed and locked it can't come un hitched.
Put the bar in place is just another step just like doing a visual.
Same is true with the Reese two jaw hitch.
He fails to realize, that all hitches require these same steps. the two are touching, the jaw is closed ,and the handle is locked. Good grief there is nothing else, unfortunately some do not do all the correct things resulting in a dropped fifth wheel.
Just because the jaws are closed doesn't mean that it's locked. On the Pullrite the jaw can close around the visible part of the pin and it still might not be locked. Furthermore, I can visually see that my added latch kit is in fact latched- no ifs, ands or buts.
I understand your system and I may do the same if I had a SB truck.
I look at the jaws closed around the kingpin and then lock the handle closed. It can't come undone at that point with the hitch I pictured above.
Neither can the Reese. I do it every time.
About Fifth Wheel Group
