Wayfarer
Sep 07, 2015Explorer
How did you get the locks through the pins. Mine only has holes large enough for carter pins. The locking lever has a hole larger enough for a lock.
Tom
Tom
Cummins12V98 wrote:tinner12002 wrote:Cummins12V98 wrote:jnharley wrote:
We had a Pullrite for 11 years and never had a problem with it. We now have a B&W hitch with the puck system in our new Dodge dually. We always do a pull test, we both visually check, and we do a light check. Safety is a priority for us and none of this takes more than a minute to accomplish.
I assume your RAM is newer than the 12 listed in your sig. 13 and newer RAM's have the puck system if ordered that way. Great option!
Your choice to do a pull test if you want but after doing your visual test and all looks correct no way can it unhitch. Of course you can if you so choose!
Is this what your hitch looks like?
I have the same setup mostly because of the hitches available for the new Ram factory setup. I have mine locked to bed but never thought about locks in pins and on locking handle...probably a good idea!
I think the locks are a good idea, some on here will tell you what a waste they are but hey do what works for you! Enjoy the Truck and hitch.
About Fifth Wheel Group
