retired-tech
Oct 21, 2013Explorer
DROPPED IT
Well I have joined the club. Pulled out yesterday and while straightening out the trailer became detached. the box on the old truck is wasted. I was wondering what kind of damage others have seen on ...
fj12ryder wrote:Ric Flair wrote:Yes and no. If you've pulled the handle, even with weight on the hitch it can be pulled from under the 5th wheel. However, if the handle has snapped forward when you've engaged the jaws, then you're good to go. Just don't forget to put the pin in the handle so someone doesn't pull it when you're not around.
Correct me if I'm wrong, but I believe the B&W hitches are less prone to this. If there's weight on the hitch it won't unlock. At least mine is that way.
And don't pin the handle in the open position. That's about the only way you can drop your trailer with a B&W hitch. It's a pretty foolproof hitch.
