retired-tech
Oct 21, 2013Explorer
DROPPED IT
Well I have joined the club. Pulled out yesterday and while straightening out the trailer became detached. the box on the old truck is wasted. I was wondering what kind of damage others have seen on ...
fj12ryder wrote:up2nogood wrote:I'll have to admit that I also don't understand why there is the ability to pin the B&W hitch open. I didn't even know it until someone posted that they had pinned their hitch open and subsequently dropped their trailer when they pulled away without realizing they had left the handle pinned open.fj12ryder wrote:Ric Flair wrote:Yes and no. If you've pulled the handle, even with weight on the hitch it can be pulled from under the 5th wheel. However, if the handle has snapped forward when you've engaged the jaws, then you're good to go. Just don't forget to put the pin in the handle so someone doesn't pull it when you're not around.
Correct me if I'm wrong, but I believe the B&W hitches are less prone to this. If there's weight on the hitch it won't unlock. At least mine is that way.
And don't pin the handle in the open position. That's about the only way you can drop your trailer with a B&W hitch. It's a pretty foolproof hitch.
No different then the Reese ,never tried to release the handle when the weight is on it, but then never seen the need, I always take the weight off before releasing the handle. Made this point before, but will again, I CANNOT lock my handle open, it catches in the open position but closes when backed into. Hard to figure out why the B&W can be locked in the open position . Yup mine is also fool proof until it isn't, just like the B&W .
