path1
Feb 05, 2016Explorer
I don't have any experience with your tank but...
If in Yuma as your location shows, good place for it to happen. I had a hose clamp pop off water line last year when in Yuma and opened up everything to dry out and put in small fan. In 2 days completely dry. I did have a hard time getting the corroplast stuff after destroying some of it getting it off. Finally ended up at the sign maker shop, just south (toward airport) from Walmart on Pacific Ave. If you have to get any parts...I would call around first. Last time ordering from RV Connection they messed up and took over a week to get part. You could order overnight much quicker and save the hassle if any parts aren't local IMO.
Also perfect time to spray paint up under around frame. Might be accessible to paint with tank out.
Hope this helps if in Yuma. I didn't have to pull my tank, just dry out all around it and install new hose above it.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
