richfaa
Feb 06, 2016Explorer
We have the 2013 3402 Montana. We had two gray tank failures thus far on our model the tank is right over the rear axle and not easy to get to. Leaking holding tanks are a common problem .The tank is in two pieces and the top of the tank usually fails. I would suggest a flexible tubing on the input and bracing under the tanks to prevent future failures. The tank will cost 130/150.00 from the vendor and if dealer installed the total cost will be around 600/800 $$$ as most dealers labor cost is 100/125 $$.We have the extended warranty and they allowed 5 hours labor.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
