laknox wrote:
So, some of you are towing up to 2,500 lbs OVER the placard GVW? Sure you're not confusing factory weight with the GVW? AFAIK, the yellow sticker is an actual, out the door weight for =that= particular unit, with specifications on =how= it was weighed. I know that Jayco's yellow sticker gives an actual weight with 1 battery and full propane, then states net cargo capacity and weight for a full fresh water tank. (scratching head)
Lyle
Not me, GVW of my 5er is 20,000, empty 15875#.."figuring" I'm loaded to about 17,000#, but will know better when I go across the scales .Doubt I'd ever hit 19K
