Infinityrver wrote:
Dual tires on the rear gives you the confidence of stability and extra tires on the axle. For a camper trailer its fine. We've all seen people overload one ton duallies, also.
My camper trailer has a tongue weight of approx. 2500lbs loaded with my stuff. My tires are light truck tires and can take 3640 lbs @ 80psi per tire. The tires can take a lot more tongue weight than what my one ton truck SRW is actually rated for. So, I wouldn't get too excited about a camper trailer overloading the tires on a one ton SRW.
Honestly, I've yet to see a lot of one ton SRW trucks towing a fifth wheel camper with blown tires and broken springs stranded on the side of the highways. Usually a blown tire will be from not enough air or warn out.
I own commercial trucks that we have to watch weights over bridges and on highways. I'm up close and personal with weights and heights on our commercial trucks.
I haul my camper from Maine to Florida and back again, problem free.
People overload all trucks, not just 1 ton dually's, they also overload 1 ton SRW, 3/4 and 1/2 ton trucks..just look around...a sad, but true statement when someone states, "everybody does it":R
The one problem with using a higher pressure tires, lets say the one's you speak of, at being able to handle 3640# each, that is a total of 7280# they can handle, BUT, if the axle is only rated at 6,000#....your AXLE has now become the weak link,, not the tires.. If you have a tire that carries more weight than your axle, you have defeated the purpose and just think you gained more cargo carrying capacity...but I don't know the RAWR of the 1 ton SRW you speak of, though I know the RAWR of a 2013 Ram 3500 SRW is 7,000#...I'd hate to think that I've not well overloaded the trucks GVWR, but have cut into 80% or more of the trucks RAWR...seems a great way to abuse one's truck and take away from safety measures built into the truck.....
Don't recollect very many, if anyone stating broken down 1 ton SRW trucks with, tongue in cheek, broken springs and on...ridiculous..all this entire thread was about was differences or reason behind getting a DRW over a SRW or vice versa....some have taken it to ludicrous levels...but, such is life as we know it in 2013....
