pianotuna
Apr 26, 2014Nomad III
Hi,
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
Yes, you can center tap for two batteries, or use a buss bar.
dballentine wrote:
Why?
Both positive terminals are at the same potential, as are both negative terminals. (Ignoring I2R loss in the interconnecting cables.)
I would think connecting the positive from the converter to either battery (or midway between the two, for that matter), and the negative (ground) to either battery, would work as well.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
