Cummins12V98
Oct 22, 2017Explorer III
"I'll not run more than the recommended in fact I would probably lower mine except my on board tire monitor would most likely alarm."
Your truck does NOT have an alarm.
Use your actual weights and compare too chart then add 10 psi to fronts and 5 psi to rears and align to specs I recommend plus 35 psi rear solo and you will be a happy camper!
Rotete fronts side to side with rotation staying the same and don't touch the rears.
About Fifth Wheel Group
