johntank wrote:
Cummins12V98 wrote:
southernsky wrote:
2019 Ram dually 65 rears and 80 fronts
YES that is what the DOOR says. 80 is correct based on weight and is correct loaded and unloaded.
BUT.....the rear pressure of 65 is for FULL RAWR of 9,750#. What is YOUR RAW and what pressure are you running loaded also solo on the rears?
Glad that they have gotten off of the 65psi for front from years back I have been running 75/80 since May of 07. Now for the rears my 07 has 45 for unloaded and 65 loaded, I found that around 55 is a good number for my 10,000# 5th wheel toy hauler with or without the toys.
Nobody got off of anything. If you believe the silly tire stickers to be universally correct, you are not very knowledgeable.
They put these stickers on vehicles because people were too dumb to put the right pressure in their tires and killing them selves.
On HD trucks, the CYA from the mfg is "fill em full".
Use your brains people. Gotta have a bit of common sense and knowledge to not be a danger to yourself!
