Cummins12V98
Oct 29, 2017Explorer III
"If your that sure post a link !!!
Its a pity that RV's aren't required to go over the scales and have inspections the same as Trucks, there again if they did there would be a lot less RV's on the road. In the mean time Suit yourself, I strongly suggest you have a meat wagon follow you, "
You asked for a link, sorry I don't know how to do that so this will have to do. Meat Wagon???
Looks like the chart you requested shows 35psi as the lowest psi. Why would they have this chart if it's not ok to use it??? As Chris noted I have WAY more capacity at 35psi than I need running BobTail. My rear axle weight is 4K empty.
About Fifth Wheel Group
