NC Hauler wrote:
MTPockets1 wrote:
NC Hauler wrote:
MTPockets1 wrote:
Dave H M wrote:
If you have been on this forum for a while, it should be apparent that a title like yours would bring out all the dually jargon.
Why not crunch the numbers yourself and get what you need and what fits your personal desires?
Me, I would never own a dually or a long bed. My F250 short box meets the towing specs and is the truck that I personally wanted.
Towing specs... probably, but I doubt GVWR... We're talking 5th wheels.. Pulling power is rarely the issue, it's the payload spec. I doubt your F250 is rated for any more than 3000 lbs. payload and probably is less. If it is and you subtract passenger weight, hitch weight and any other cargo from your payload door post number, then subtract your fully loaded 5vr pin weight, you would be OK, but I would be surprised. My 35 ft. 5vr pin weight is 3400 lbs fully loaded, plus I have to add passengers, fuel, and cargo and that brings me close to 4400 lbs.. No F250 can do that, and no F350 SRW can do that. It goes beyond tire capacity, not to mention truck.
There are 1 ton SRW trucks out there now, Ford GM/Chevy or Dodge that CAN tow the 5er you're talking about. I'm talking 2013-2015 1 ton SRW trucks, but yes, they can tow that weight and not exceed the trucks RAWR...
I was a BIG stickler of GVWR, but over the years have found out more and more, that most use RAWR...Now, with my truck and load, I'm even under my trucks GVWR of 14,000# and WELL under it's 9750# RAWR (actually rated to 11,800#)...BUT, yes, there are 1 ton SRW trucks out there today that can handle weight you are talking about...do the research.
. The Ford website for 2015 payloads, does show F250 SRW payload max up to about 4200 lbs. But- that's for a bare chassis model. A loaded F250 SRW 2WD crew cab max payload with Diesel engine will max out under 3100 lbs.
I was talking about a 1 ton 3500 SRW truck, not a 2500...The weights they can tow and payload they can carry now have gone up quite a bit in the last couple of years...Don't know that much about the 2500, but was talking about a 1 ton SRW truck.
. Ah, 3500, F350's, SRW trucks may have payloads up to 3800 lbs or so depending on actual truck and options. I had a 2012 F350, SRW King Ranch and payload per door post was 3460, so I was overloaded. I ordered truck and assumed the catalog specs were correct - Big mistake by 600 lbs. I bit the bullet a year later and got the DRW for piece of mind. No regrets and now have some extra capacity.
