M_R_E_
Jan 15, 2022Explorer
Dumb mistake
I filled up my 5 gal can with diesei in back of pickup when towing and forgot to put cap on and drove for 3 hours in light rain. Will some water damage the fuel ? Is there something I could add to the...
Cummins12V98 wrote:This is the best advice here. The water WILL settle to the bottom, so don't pour the entire container into the clean container. Just let the clean container sit to make sure you didn't pour too much fuel out. As someone else mentioned, use the bottom fuel to start a fire.
Water will settle to the bottom, it will roll around on the bottom looking like mercury. Slowly pour it into another container thru cheesecloth until the water is close to coming out. Now let the new container set for a day and then pour most of it into your truck.
Slosh around the containers and then pour out and let them set upside down to drain. Done!!!
