M_R_E_
Jan 15, 2022Explorer
Dumb mistake
I filled up my 5 gal can with diesei in back of pickup when towing and forgot to put cap on and drove for 3 hours in light rain. Will some water damage the fuel ? Is there something I could add to the fuel ?
Lantley wrote:SDcampowneroperator wrote:
A few raindrops will settle out and be separated in your water filter. At worst case you will get a 'Water in fuel ' check light.
If you do, stop as soon as it is safe, , open the drain on the bottom of the filter and let it drain until the droplets 'sheet off' no longer 'beading off ' as droplets. A few pumps on the primer pump will help.
Use of a diesel fuel conditioner like Howes, Sea Foam or Diesel Service will dissipate water , for dissipation, not ridding the water.
Even treated dissipated water is harmful to common rail HPS diesel pumps.
Avoid the issue, deal with it, do not try to 'treat'' it away.
Seems like a lot to go through for $20.00
M.R.E. wrote:
Thanks for all the responses. Not worth the risk, but where do you dispose ?
MFL wrote:
Three pages of response, but OP has not returned. With the mixture of solutions, I wonder what the OP plans to do? I am guessing he hates to waste the small amount of fuel, or he would not be asking. Is it safe to use, worth trying to separate, worth the stinky mess on your clothes, hands, and shoes? I think OP was asking, should I just dump it in the truck, or not?
Let us know OP, is it worth the risk to YOU?
Jerry
Exactly my point. Treating away the water is more costly than dumping suspect fuel.
That raises another issue, how and where to dump contaminated fuel?
Theres the kicker, do you trust the water separator filter and do you know how to service it? If not, read you tube for a minute about your truck.
