jlud's avatar
jlud
Dump Station Problem....
So they Carbon 33 worked good, went to leave and use dump station as the first time used without full hookups. Valves were pushed in for closed and all the way. Went to unhook my trailer pipe cap and water (smelled gray) was spraying out, lots of pressure. Drained a bit on the ground by dump and it showed no sign of letting up. Pulled the grey valve as I was thinking maybe i had them backward and heard it open and flow, so I shut it quick.
After a while I just pulled off the cap and slapped on the hose as fast as I could, water flowed out it the entire time. Once attached, I dumped black and heard and verified it went, then dumped gray and it flowed and went....
I believe I only have one gray tank....any ideas why the full pipe and pressure with valves closed? Like I said, both tanks emptied when valves pulled...my only thoughts gray water not closed all the way or valve failure allowing some flow?
Thanks,
