mielockExplorerAug 15, 2015Dump valve replacement gone badI was mostly concerned about how to get a new dump valve in place with seals intact between two immovable objects until I tried to remove the faulty one, which I did not succeed. After removing the 4...Show More
24fb_freedomExplorerAug 15, 2015Try looking further down the line to see if there is any brackets you can remove to give it some play.
Related ContentVoltage Dump Valve Replacementstuck dump valveDump Valve ReplacementReplacing dump valvesair dump valve replacement
