mielockExplorerAug 15, 2015Dump valve replacement gone badI was mostly concerned about how to get a new dump valve in place with seals intact between two immovable objects until I tried to remove the faulty one, which I did not succeed. After removing the 4...Show More
newman_fulltimeExplorer IIAug 15, 2015use a ratchet strap to lightly pull at the elbow to give enough clearance
Related ContentVoltage Dump Valve Replacementstuck dump valveDump Valve ReplacementReplacing dump valvesair dump valve replacement
