therink
Aug 15, 2015Explorer
If it were me and I couldn't loosen the drain pipe enough to get flex to unseat the valve, I would likely cut the 3" drain pipe with a saw and reconnect using a 3" fernco connector.
The use of aluminum flashing between the valve seats to remove and reinstall is good advice.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
