Old-Biscuit
Aug 15, 2015Explorer III
Best have some more epoxy on hand..by the time you get that valve out and new in you leak will be back.
Drain line is too rigid hence the hairline crack at tank connection.
Line should be supported but have a little flex to absorb road vibrations.
As suggested...check for bracing that can be loosen/removed on line downstream to allow for some movement.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
