rhagfo
Aug 15, 2015Explorer III
ol Bombero-JC wrote:24fb freedom wrote:
Try looking further down the line to see if there is any brackets you can remove to give it some play.
Been there, done that - loosen brackets to allow movement.
Might be time to re-engineer the entire tank & plumbing set-up.
Whether you drop the tank or not.....
A "standard" (not remote) valve closer to the final exit section
of 3" pipe is great "old school" - easy to access for anything!..:C
X2!
I have a leaky grey water valve, the drains on my grey and black tank face each other and connect to a "Y" between the tanks.
I used the I got one of the exit valves, and for now that works, but I really want to correct the valve issue and replace it.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
