Carl_n_Susan
Aug 15, 2015Nomad II
Halmfamily wrote:therink wrote:
If it were me and I couldn't loosen the drain pipe enough to get flex to unseat the valve, I would likely cut the 3" drain pipe with a saw and reconnect using a 3" fernco connector.
The use of aluminum flashing between the valve seats to remove and reinstall is good advice.
This is how I replaced my 3" valve. Much easier to do if you need access in the future, loosen the two clamps and pull the pipe apart.
This is what I did too. The other advantage is you can control the tightness of the valve connection (i.e. the pressure from the 3" pipe which squeezes the valve housing) to ensure it isn't difficult to open.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
