Cummins12V98
Aug 16, 2015Explorer III
" I would likely cut the 3" drain pipe with a saw and reconnect using a 3" fernco connector"
EXACTLY!
I would NOT slide metal between the parts you could scratch the mating surfaces and cause a sealing problem with the new valve.
CUT THE PIPE!
EXACTLY!
CUT THE PIPE!
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
