mielockExplorerAug 15, 2015Dump valve replacement gone badI was mostly concerned about how to get a new dump valve in place with seals intact between two immovable objects until I tried to remove the faulty one, which I did not succeed. After removing the 4...Show More
magic43ExplorerAug 19, 2015In this instance, Fernco fittings can be drastically shortened with no ill effects.
Related ContentVoltage Dump Valve Replacementstuck dump valveDump Valve ReplacementReplacing dump valvesair dump valve replacement
