One of my dump valves has started leaking, just a drip for now . I have never had one of these apart, do you just take the 4 bolts out and slide the valve out and I would guess put new gaskets in. Any...
Replacing the gate valve is no big deal as long as you can actually get to the valve. On our fiver, the valves are located behing the cloroplast sheeting which would require removing the fasteners and dropping the cloroplast. Removing those sheets is not a big deal as you have gravity working in your favor. Putting them back up however is a completly different proposition.
