jparker66's avatar
jparker66
Dump Valves
I own a 2009 29" Holiday Rambler Savoy SL. I have one dump valve that I can open the black water valve, empty it and then open the grey water valve and empty that one. I have replaced the valves 3 times. Still leaking a little. When I take the cap of nasty smelling stuff comes out -- about a quart. When I repaired the last time, I really lowered the entire pipe so I could get the valves installed. The last one was still very hard to installed.
Has anyone modified this and converted to two separate areas to connect the hose. One connection for the black water and then take off the hose and connect to the grey water. If I was working with PVC, no problem.
Or is there a better way to install the two valves since they are very tight?
Thanks for any comments.
James
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,412 PostsLatest Activity: Jul 15, 2026
