lfr101
Jun 04, 2014Explorer
The voltage is in fact produced by the magnetic lines of force produced around the high voltage conductors, the higher the voltage and current the larger the amount of induced voltage you will get, this is the same way as a transformer works. If you drop a small piece of chain from the frame of the trailer to the ground this should drain off the induced voltage.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
