biggamehunter24's avatar
Jul 13, 2014
EFI Reset Location?
I have a 2004 Prairie schooner 5th wheel camper that is 31 feet long. Currently I have no power to the outside outlets to the right of the side door. I have checked fuses and none are blown and all other outlets in the trailer appear to be working.
I need to find out where the EFI plug reset is located in the trailer.
Any ideas?
  • If it's not bathroom or kitchen, check your basement outlets. If the unit is fairly new to you, you may discover an outlet you have never found before. Some builders are pretty good at hiding them.
  • The outside outlet is required to be wired from a GFCI protected circuit. But it may be wired from a GFCI outlet somewhere inside. Look carefully all around for any GFCI outlets inside (with the little pushbuttons on them), especially in the kitchen and bathroom area, and press the reset button on each.
    Any ideas?
    had the same problem mine was reset with one of the ground fault plugs in the kitchen.
