tinner12002
May 24, 2016Explorer
EFI onan
Has anyone considered going to an EFI generator on their toy hauler instead of the carb unit?? I have discussed getting an EFI one when looking at ordering a new hauler. Dealer said not a problem.
dohler1 wrote:
Spoke to my local ONAN dealer about this exact issue. Here is what they advised:
needs the following in the Fuel tank:
--Supply return & purge lines for the EVAP EFI unit.
--Has to be rewired to just produce 120 volt as they are 120/240 volts
5.5 HGJAD-6759(diamond symbol)
if you have figured this out please let me know. I have the 5500 carbureted one now. I am always having issues with it. Want to go EFI on our new one.
allcool wrote:offtohavasu wrote:
Oddly enough, as it runs cleaner, it doesn't show CARB compliant on their website.
Interesting...
Although I have browsed CARB before on occasion, not up on its exact operations or guidelines.
Many manufactures find loopholes if the engine in question is more or less the same model/series as previous engines that have passed CARB. Not saying thats what happened, or that Onan is running with a non compliant genny, ijdk..?
More than likely if a carbureted engine that is more or less exactly the same, passed CARB, then the efi version should at least be as clean you would think, yes..?
jmo
