Texas_Bohunk's avatar
Texas_Bohunk
Electric Awing won't close
I have a 2014 Forest River V-Cross VTSB365 my problem is the awning will open up with no problems. When I got to close it, it stops intermittently. If I wait a second and hit the close button it starts again but stops within a few seconds. Is there any adjustments for the closing torque or springs that I can adjust to correct this problem?
Thanks in advance.
  • IB853347201 wrote:
    Sounds like you have a voltage problem to me. Your TT's battery is at least 4+ years old, when did you last check the after levels? Is it toast?
    It may be a voltage problem, but he said it has been doing this since it was new.
  • Sounds like you have a voltage problem to me. Your TT's battery is at least 4+ years old, when did you last check the after levels? Is it toast?
  • It could be a bad auto resetting breaker. I had that problem a few years back. Replaced it and no issues since. Mine is an automotive type and I got it at NAPA.
  • If you have access to a load meter, you might check the load the motor is pulling when retracting. Could be something else binding.
  • My problem is it has done this since new. Dealership looked at it twice. But I will look at the wiring just to be sure.
  • You need to check the motor and connections to make sure you've got a good connection. Most of the power awnings don't have well protected motors and/or connections. Best way to check would be to hook up a battery directly to the motor and see how it operates. If it's still slow, time for a motor replacement. But if it works fine, then check connections, switches, and wiring in general.
    I had to replace the motor on my power awning, it was doing the same thing as yours. I got a new motor off Ebay, and it was about half the cost of one from an RV vendor.
