sk734
Jun 03, 2013Explorer
smkettner wrote:
The amp draw s/b close to 3 amps per wheel. Have you measured it? Either high or low is bad.
I assume you are experienced in drum brakes? Might be best to have a second experienced person help inspect the braking action one at a time.
Could be the shoes need to wear in a bit and this could take some time if the drums were not turned.
I have been told amps can be 3 to 5 amps per wheel. What do you call high?
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
