Vulcaneer
Jun 05, 2013Explorer
Larry. Now that you have your brakes fully seated to the drums, you might want to go back and re-adjust them again. Because once you have worn off the high spots on the shoes, the brake adjustment is now less than it should be for full travel. Your shoes are a bit thinner than they were on your first adjustment. So that initial break in wear needs to be compensated by adjusting out a little more.
About Fifth Wheel Group
