remdog_1's avatar
remdog_1
Electric Brake Problem
Just returned from trip, stopped over last night and left truck hooked up to fiver. I also left 7 pin plugged in and then hooked up to campground electric. When I left this morning, the electric brakes were locked up. Did leaving it plugged in to truck cause a problem? I attempted to back off on juice to brake controller but it did not seem to help, had to stop every 5 miles or so to let brakes on camper cool off, if I continued it would cause smoke coming off brakes. I was able to get home OK, but any suggestions what to check first. Camper is Brookstone 345SA, using Tekonsha Primus brake controller. Ford F-250 Super Duty
  • The fact that you were able to pull the trailer 5 miles at a time before cooling the brakes tells me that they needed adjustment even before you had this problem. You probably need a complete brake job now.
