Griffin's avatar
Griffin
Electrical problem
Hey all, wondering if someone could shed some light on an issue I’m having. I have a 95 rustler tt, 24ft. Not sure the specific model. Parked it last fall everything was working fine. I had the battery removed so it wasn’t left in the cold. Kept it well charged over the winter. I recently went to get the trailer going for the season, installed the battery and for some reason no power to the fridge, range hood (only the battery level indicator and tank monitors) and the propane sensor located below near the floor. The other functions on the range hood are working such as the light, fan and water pump switch. I’ve checked the fuses and they are all fine. Plugged into a/c from the side of the house and same thing. Can’t figure out why only these three items are without power. The fridge outlet at the back of the fridge is live so I assume just the controller (thermostat) portion runs on 12volt. I don’t know much about how these things are wired so any insight would be great before I haul it to the dealer to have it diagnosed. Thanks in advance.
