justme's avatar
justme
Electric brakes
A vandal took my brake-away lanyard that energized my brakes to where the batteries ran down completely. Does anyone know if the brake magnets could be damaged for being energized until two batteries go dead over many hours? The brakes magnets are for Dexter 7,000 lb axels. The resistance reading is one ohm which may be ok with 4 magnets in parallel that are 4 ohms each. However, that does not rule out shorted windings. Does anyone have experience with this situation?
  • My suspecion is if the magnets went bad, they would have burnt up and shorted out. You should be able to check for resistance thru the wires and if you do not have a dead short, they should be OK.
    Have you checked the lead wires to the brakes? Are they burnt or bubbled? That would also give you an indication if the magnets overheated and are damaged.
    Then that her for a drive. - I like the disconnect idea! I use it!
  • Here is what the mfg says to my request: "It depends on the batteries powering the break away system. If the batteries are the standard small gel cells typically 5 to 7 amp hour capacity they are likely fine. The magnets would of pulled the batteries down in 15-30 minutes and while they would of gotten very hot they usually escape this unscathed. If you had larger deep cycle batteries on the circuit that typically power the living area when away from shore power it would of taken hours to kill the batteries and the heat for that length of time may have done some damage. A careful test drive will tell you the most. Even disassembly and visual inspection may not reveal any issues if the wire melted its varnish inside the magnet. I've included a direct link below on our magnet testing article incase you want to check them individually."
