john_bet
Aug 02, 2014Explorer II
I do not believe a repair kit will help you. I have mine apart now and you still can not pull out the inner movable leg so I think you you have a broken traveling nut support. I think your only recourse is a new leg. Mine has a sheared pin in the vertical shaft to the top gear.
About Fifth Wheel Group
19,027 PostsLatest Activity: Oct 29, 2025
