jtbuilds wrote:
Our 2016 has setting for Elec and Elec over Hyd. and low med high braking effort as well as the 0-10
If you have 3 axles with Dexter disc (large pistons) brakes a second or larger pump maybe needed.
Also check to see if the brake were bled properly.
^^^ What they said ^^^
Our "15" has 2 separate settings in the dash menu . . .
1 is for Electric . . or Electric/Hydraulic
1 is for brake intensity . low-Medium-High
then there is the 0-9 on the on board controller . .
I have my settings at: Electric/Hydraulic - MEDIUM - 6.5
