Old-Biscuit
Nov 01, 2017Explorer III
MFL wrote:BlueJean wrote:
I haven't checked the outside shower valves. Interesting stuff. I'll do it when I get back to camp.
In OP, you said water heater works fine on propane. If this is true, then it cannot be the outside shower valves, as you'd be getting a luke warm shower on propane also.
If the water heater on electric, does not get hot prior to taking shower, or washing dishes, then problem is likely electric side thermostat.
Jerry
YEP^^^^
Use a voltmeter to check where 120V AC stops to ID problem
IE: Circuit breaker, ON/OFF Switch, T-stats, element
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
