TakingThe5th
Apr 06, 2014Explorer
richfaa wrote:
"We own a 2013 Keystone Cougar 5th wheel model 331MKS. It is 11 moths old"
be that the case it is still under warranty. Call the keystone service center and get the problem recorded. call you dealer now. If it is under warranty you have no problem.
X2. As others have said - you did an outstanding job.
Our 333MKS is at the dealer now as it turns 12 months old, having work done on the punch list, so I am extremely interested in the outcome of your problem. One of our punch list items is to have the defective control panel replaced, so I will take that opportunity to see if I can strike up a conversation and gather some additional information.
Previously I was told that the landing gear does bypass the main disconnect switch - they said it was a safety feature because the landing gear should always be available.
Our unit has several notable oversights - whoever designed the electrical systems on this generation of Cougars needs to be better connected - or fired. :E
About Fifth Wheel Group
