jquattlebaum
Mar 26, 2014Explorer
Electrical Issue
I recently purchased a 2006 Keystone Cougar. At first I had to disconnect the battery in order to preserve it. Then at one point I accidentally crossed the wires to the battery while it was sitting in my yard. I didn't get it fully connected because as soon as I touched the second wire to the post it sparked. I have since installed a 30 amp RV power source. However when I connect to the shore power, it seems as though I have to occasionally go back and flip the main breaker off and back on to get the shore power to work. Here is what I get: when I flip the breaker the battery light in the panel (galley, black, grey, fresh, battery) shows full and the RV lights get brighter (if burning). After a while when I check the panel again the battery is showing 2/3's or less in some cases depending on how long I go between checking it. I noticed this during the past weekend which was the first time I had been camping in the RV. Is there a fuse or something that could be blown? Or is my power converter going bad and how can I test that? Or is my battery bad and how could I test that? I have checked the water level in the battery and most of the time it shows 14 to 14.5 volts when hooked up. Any help is greatly appreciated by this beginner.
