Woodtroll
Aug 27, 2017Explorer
What adapter are you using? I'm assuming that you need 50-amp service with those two ACs. If you don't have a 50-amp receptacle, you're not going to get everything to work. You say you have 120 volts on the volt meter, but is that on each leg of the 50-amp service?
Important question - have you used this receptacle before and gotten everything to work on it?
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
