CA_Traveler
Dec 14, 2014Explorer III
Matt1971 wrote:Pull the plug and start the gen. Then carefully check for voltage on the male plug end. Voltage there means that you have a very dangerous setup.
I found it on all the outlets. I haven't replaced the 30a end so maybe I need to check that first?
It looks like the company did just hard wire it together because I can't find a transfer switch anywhere.
I've been wondering if possibly the ATS was removed. Hard to understand why someone would remove it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
