Dayle1
Dec 24, 2016Explorer II
Bosemoe wrote:
Ok, when I got home my wife told me the power had been off for hours. So I went straight for the campers panel box. I got all 4 screws out that were holding the cover on and the instant I started pulling the cover off the power popped on, so it's definitely in the panel box. I checked every screw I could and couldn't find one that was loose. I wiggled every wire that I could and never saw even a flicker in the power. Hopefully next time it goes out it will stay off long enough for me to get the cover off and the multi meter in there.
I had a breaker and the hot lead had been jammed behind the terminal and the screw was tightened down on nothing. It worked intermittently. Don't just check for loose screws, try pulling each wire (with power off).
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
