- way2rollTrailblazer
It's also helpful if you return to the forum to read responses to your question.
- Grit_dogTrailblazer
Don’t sit there…
- bid_timeNavigator
Is the pass-through under the bed? Look in there for a bad wire/wiring as described by way2roll.
Sounds like a damaged or loose wire under the bed. Look for a wire somewhere under the board under the mattress, under the frame, in a hinge, in an outlet etc, that is loose or has rubbed and exposed the wire. If it's shorting other things in the circuit, it's probably an outlet. Likely when you sit on the bed, the wire is moving and arcing or getting pinched or touching metal and causing a short.
