tommyznr
May 28, 2021Explorer
You say you have 12V at the switch when it is open and 0V when it is closed. So closing the switch is shorting the circuit to ground. Since you can run a wire direct to the motor bypassing the switch without shorting to ground, I suspect that your switch is shorting to ground.
Can you remove the switch from it's mounting position and let it hang if free air? You could then operate the switch and see what happens.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
