- TimnJoExplorerNot quite applicable as mine is the 30A portable, but I thought mine had failed as I wasn't getting any voltage after the display cycled when first plugged in. I then noticed that if I left it plugged in for a while a little LED in the bottom right hand of the display would stop flashing and I then got voltage inside the coach and I was still protected.
This wasn't mentioned when I called tech support, they just said they'd send me a new one until they found out I wasn't the original buyer. - edatlantaExplorer II
laknox wrote:
edatlanta wrote:
Originally I had two PT50C's (original design). The first one that had a problem saved me from a surge or something and one leg died in September 2016. I put my spare in service and sent the bad one back. They replaced it with the new design PT50X. In March 2017 my other original PT50C got wet from a major rain storm and it was replaced under warranty with the PT50X also. This was blowing rain not submerged so the new design with the cover is a nice addition.
I have been using my first PT50X since and it is working great. But I still have a spare one.
That's good news. Maybe I will reconsider the portable. Biggest complaint about the weather cover is that, if you have a handle on your shore cord, the cover won't close.
Lyle
It won't close completely, but it covers a whole lot better than the original which had no cover. This only an issue for me if I have to use my 50A extension which I have had to use only 1 time. - laknoxNomad
Lyle - edatlantaExplorer II
laknox wrote:
alexleblanc wrote:
edatlanta wrote:
time2roll wrote:
If the EMS completely fails just remove it. Just 4 wires to move or twist on some large wire nuts to bypass. Mine (30 amp hardwired)is working fine for a decade.
When my PT50X portable fails after taking a hit or other reason, I just unplug it and plug in my spare. Yes, I have 2 of them. Worth every cent they cost. While the dead one is going back for service I'm still protected. This has happened 4 times over the past 8 years of full time use.
i'm glad to see somebody other than me carries a spare - so many shoddy electrical systems in campgrounds, good to have piece of mind.
From my recent reading, the new versions of the portable unit are not getting stellar reviews. 2 biggest complaints are the incompatibility of the weather cover and today's large cords, especially 50a, and the weather-tightness of the unit, which has caused failures and they seem to not be wanting to warrant them without hassles. I plan on a hard-wired unit because of this.
Lyle
I have been using my first PT50X since and it is working great. But I still have a spare one. - edatlantaExplorer II
You are the only one I have ever run into that had a spare besides me. My comment about mine is "I will NEVER EVER plug in anywhere without my PT50X". I even had a high voltage issue at my home base site at one point - Failing power company transformer. The lineman that came out wanted to know what I was using to determine high voltage. After he looked he said he was going to order a PT50 himself for his RV. - Dennis_M_MExplorerHave had one over ten years see my post here
- john_betExplorer II
alexleblanc wrote:
I have not found any in the last 17 years, nor from '82 to 84. And yes I have been out of my home area.edatlanta wrote:
i'm glad to see somebody other than me carries a spare - so many shoddy electrical systems in campgrounds, good to have piece of mind. - laknoxNomad
Lyle - RollandBExplorerWe’ve had low voltage detected twice. Checked the pedalstal with my multimeter to confirm it, then changed the fridge to gas only, shut off the AC and only used the 110 ac I was willing to have damaged
- WeXtheUSExplorerThank you everyone for your time and response. I'll put one on order.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
