batavia02 wrote:
Question while we think we know what we want I do have a few more questions,I will use forest river has a example what is the difference in a wildwood heritage glen or a sabre. Vs a high end model is it the difference in the quality of the mattress I can replace the mattress. The brand of tv I can go to Best Buy and get a better quality, we all know the quality of the tires are poor I can put in higher quality tires and rims .I can put in better furniture so what is the difference overall ?
Thousands of items
Pinbox deflection 1/2" or 3/4" or 1" or 1 1/4 or 1 1/2" or 2"
Chipboard vs. Plywood
A screw vs. a staple to hold items together
Vinyl flooring .050" vs .100"
Printed veneer on MDF vs wood veneer vs solid wood
0.060" vs 0.080" vs .100" aluminum
wood blocking for screw retention in the alum tube or none at all
Screwed & glued vs welded alum
8" or 10" or 12" I beam frame
.060 sheet metal cross members or full I beam
fiberglass vs. gel coat sidewall
1lb vs 2lb foam insulation
1/4" vs 3/8" vs 1/2" thick tank walls
1 1/2" vs 3" dump valves
6 gauge vs 4gauge wire
10gauge vs 12gauge wire to the slide motors
Shwinteck vs steel under mount slide mechanism
......an endless list
