Low_Timer
Jun 02, 2019Explorer
EOH Brake Question
I recently converted my electric brakes to EOH disc brakes on my tandem axle fifth wheel. The brakes are a great improvement over the electric brakes, but may have an issue to be resolved. While testing the brakes, I drove to a gravel road to check even braking with all four wheels. Using the lever on the P3 brake controller, I could lock the wheels on the front axle, but not the rear axle wheels. The trailer weighs approximately 14,000 pounds. Thinking I may have some air in the rear axle lines, I returned home to bled the lines again. Tested again on the gravel road, still unable to lock the rear axle wheels. When I returned home, I used an infrared thermometer to check the rotor temperatures. All four rotors were within 5 degrees of each other. There are no kinks in the lines between the front and rear axle.
Has anyone experienced the front axle brakes would lock up, but not the rear axle brakes? I bled a third time with no air detected.
Appreciate your thoughts, thanks.
