- laknoxNomad
ACZL wrote:
Just another thought here, but were the wet bolts installed so the holes in them are at the 3/9 o'clock position?
Every post I've read about this at least claims to have the bolts installed in the correct orientation.
Lyle - ACZLExplorerJust another thought here, but were the wet bolts installed so the holes in them are at the 3/9 o'clock position?
- laknoxNomadEasy enough to check. Drop a small drill bit down each hole and, if you can't see it, then send the whole thing back...under warranty, on their dime. You'd think it was an LCI product...
Lyle - C_SchomerExplorerWow, it was about 2012 that I got those bad bolts and it was when I bought Dexter easy flex and wet bolt/shackle kits from E trailer. Several guys posted that they had the same problem. I wonder how many more of those bad bolts they have! Craig
- ScottGNomad
C Schomer wrote:
I’ve had some of the wet bolts that weren’t drilled all the way through and there was no way to get grease into them. Craig
Same here, didn't realize it until the next year when I went to grease them. eTrailer told me "Sorry".
Haven't bought anything from them since. - RCMAN46ExplorerIf you have never had the Equa-flex take grease Schomer is on the right track. When I installed my wet bolts I also had several that were not drilled all the way through.
- C_SchomerExplorerI’ve had some of the wet bolts that weren’t drilled all the way through and there was no way to get grease into them. Craig
- ACZLExplorerX3 on raising the susp off the ground.
- southernskyExplorerJack it up from the frame and stretch your suspension
- buc1980ExplorerTake the pressure from the wheels pick up some from the ground.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
