bad99ram's avatar
bad99ram
Error Code Lippert 3.0 6 point Level up
We have a 2016 HC 375FL. Yesterday we had a error code on the level up system after many hours of trying different things , reading the manual and looking on the internet here is how to clear the error code. This is for the electric jacks
1. Hook up truck
2. Retract all jacks ( you need to use manual mode)
3. Extend all Jacks at least 6" ( for the middle jacks, press right and left at the same time)
Now that all are extended , press and hold retract button until all jacks are retracted.
4. At this point the error code reset and system was back to normal.
1 Reply
  • I had the same thing happen to me a while back except i couldn't get the RF high enough to do that. I was on a really unlevel site.
    I ran it up manually with cordless drill. It took forever! Then i disconnected the hall effect sensor and tried run jack so it would put out an error message. Then i could retract it as the above post says.
    The lippert tech guy was very helpful. I'm going to pick more level dites from now on.
